Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The PRAM battery is located underneath the logic board.
O que você precisa
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
Lift the edge of the PRAM battery slightly with your fingertip and use a spudger to slide the PRAM battery out from under its socket's metal clip.
3 outras pessoas executaram este guia.
