Introdução
Remove your front bezel to gain access to your iMac's internals.
O que você precisa
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Using a strongish magnet will grab and release the latches.
Citação de darkstar448:
Are you sure it's safe to do this? How close is the hard drive, won't magnets interfere with it?
It's almost certainly fine. Modern hard drives are very resistant to magnetic fields.
