Introdução
Remove the fan cover to replace your upper fans or hard drive.
O que você precisa
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
5 outras pessoas executaram este guia.
