Introdução
Easily replace your AirPort Extreme card to regain wireless connectivity.
O que você precisa
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
23 outras pessoas executaram este guia.
