Ir para o conteúdo principal
iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement
O que você precisa
  1. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement, Bottom Plate: passo 1, imagem 1 %32
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: passo 2, imagem 1 %32
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: passo 3, imagem 1 %32
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement, Bottom Plate Housing: passo 4, imagem 1 %32 iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement, Bottom Plate Housing: passo 4, imagem 2 %32
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: passo 5, imagem 1 %32 iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: passo 5, imagem 2 %32
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Conclusão
6 outras pessoas executaram este guia.
Justin
Membro desde: 10/05/11
303 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 21-22, Maness Fall 2011 Membro de Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
Membros da 4
Autoria de 13 guias
Um comentário
If you do this - don't you still need to apply a fresh coat of thermal paste to the exposed ends of the two heat-sink posts (that separate when you open a G4 flatpanel this far) - my understanding was that the machine would overheat and you'd be left with didley squat!!
Gregg :O)
amicuset - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 2,143
