Ir para o conteúdo principal
iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement
O que você precisa
  1. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Outer Base Plate: passo 1, imagem 1 %32 iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Outer Base Plate: passo 1, imagem 2 %32
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: passo 2, imagem 1 %32
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, RAM DIMM: passo 3, imagem 1 %32 iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, RAM DIMM: passo 3, imagem 2 %32
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
    You to not need to remove the RAM to complete this task.
    douglux - Responder
  4. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Removing the Lower Case: passo 4, imagem 1 %32
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  5. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: passo 5, imagem 1 %32 iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: passo 5, imagem 2 %32
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
    You can skip steps 7-9; there is no need to disconnect any internal wiring or RAM. Crack open the base a couple of inches (it doesn't really rotate, just pull it out), and the PRAM battery will be right under your nose. It's no problem to pop it out with your fingers and put the new one in. Just make sure that you note the positive and negative terminals on the old one, and put the new one in the same way.
    whshep - Responder
    No one mentioned the need for thermal paste in the reassembly...
    Federico Jimenez -
    Thermal paste? Where would you put that? As I understand it there's no need for that anywhere other than the CPU/Heatsync
    Steven Hatch -
    There's a post (or block really) that connects the cpu heatsink to the upper part of the metal shell that is just to the right (facing the imac) of the drive door. Upon reassembly it's best to clean the matching surfaces and reapply thermal paste to that upper post.
    Joe Pena -
    what's with the apparent loose black wire visible in step 6 & 7 ?? same as the loose wire just sitting there in step 3 ( which was like that on mine, just loose.....? )
    rickcee44 - Responder
    I hear that wire is bluetooth hook up.. my model has the other side but my board doesn't have the hook up... go fig :(
    sean -
    agreed with whshep. I did not disconnect these cables to complete this repair.
    douglux - Responder
  6. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: passo 6, imagem 1 %32
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
    The black tab is in in the middle of the plug (facing us in the photo.) Pushing not very hard on the top unlatches the bottom.
    Matt D - Responder
    I got away with not disconnecting these cables and was still able to complete the repair.
    douglux - Responder
    What if I remove the grounding cable
    Roman - Responder
  7. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: passo 7, imagem 1 %32
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
    It's a bit vague. That is, it explains where and how the memory module fits, but most importantly it does not. What type of DIMM memory it has to be and its speed as well as the process of not touching hands with the gold connectors of the memory module
    Carlos Sousa - Responder
    I left this connected as well. Was able to complete the repair with it connected.
    douglux - Responder
    What is this ribbon called? I need a new one and don’t know where to find one.
    Ian Young - Responder
  8. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Internal RAM: passo 8, imagem 1 %32
    • Release the tabs on each side of the module by pulling them away from the internal RAM
    • Once the tabs are pulled the module will "pop" out and you can slowly remove it.
Conclusão
19 outras pessoas executaram este guia.
Lilly
Membro desde: 10/11/11
632 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 5-32, Amido Fall 2011 Membro de Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
Membros da 4
Autoria de 8 guias
2 comentários
It's a bit vague. That is, it explains where and how one has access and how the said memory module fits, but most importantly it does not. What kind of memory are we referring to, just as it does not explain the type of memory it has to be and its speed as well as the process of not touching hands with the gold connectors of the memory module
Which memory bank is inside Bank 0 or Bank 1?
Michael Inman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 47
Duração total: 11,653
