Ir para o conteúdo principal
iLive IKBC384S Power cord and connector Replacement
O que você precisa
  1. iLive IKBC384S Power cord and connector Replacement, Top Cover: passo 1, imagem 1 %32 iLive IKBC384S Power cord and connector Replacement, Top Cover: passo 1, imagem 2 %32
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Power cord and connector Replacement: passo 2, imagem 1 %32 iLive IKBC384S Power cord and connector Replacement: passo 2, imagem 2 %32
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Power cord and connector Replacement: passo 3, imagem 1 %32 iLive IKBC384S Power cord and connector Replacement: passo 3, imagem 2 %32
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Power cord and connector Replacement, Power cord and AC connector: passo 4, imagem 1 %32
    • Remove the one (13.5mm in length) srew holding the power connector and cord in place.
  5. iLive IKBC384S Power cord and connector Replacement: passo 5, imagem 1 %32
    • Remove the power cord connected to the motherboard.
Conclusão
Allen Dover
Membro desde: 03/21/17
401 Reputação
Autoria de 4 guias
Equipe
Texas Tech, Team S46-G6, Bennett Spring 2017 Membro de Texas Tech, Team S46-G6, Bennett Spring 2017
TTU-BENNETT-S17S46G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 319
