Ir para o conteúdo principal
iLive IKBC384S Motherboard Replacement
O que você precisa
  1. iLive IKBC384S Motherboard Replacement, Top Cover: passo 1, imagem 1 %32 iLive IKBC384S Motherboard Replacement, Top Cover: passo 1, imagem 2 %32
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Motherboard Replacement: passo 2, imagem 1 %32 iLive IKBC384S Motherboard Replacement: passo 2, imagem 2 %32
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Motherboard Replacement: passo 3, imagem 1 %32 iLive IKBC384S Motherboard Replacement: passo 3, imagem 2 %32
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  5. iLive IKBC384S Motherboard Replacement: passo 5, imagem 1 %32 iLive IKBC384S Motherboard Replacement: passo 5, imagem 2 %32
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Disconnect the two power connectors from the motherboard.
  6. iLive IKBC384S Motherboard Replacement: passo 6, imagem 1 %32
    • You will need to desolder the antenna.
    • Be sure to desolder the piece connected to the motherboard not the wire.
  7. iLive IKBC384S Motherboard Replacement: passo 7, imagem 1 %32
    • You will need to remove the speakers and power connector.
    • Once you have removed all of these from the motherboard, the motherboard can be removed
Conclusão
Tracy Walts
Membro desde: 03/21/17
201 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team S46-G6, Bennett Spring 2017 Membro de Texas Tech, Team S46-G6, Bennett Spring 2017
TTU-BENNETT-S17S46G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 277
