Introdução
You will be replacing the entire disk drive in your radio, the only special tool that is needed for this replacement are the iOpener or heat gun because of the adhesive.
O que você precisa
Make sure you remove all seven 3 mm screws before proceeding to the next step.
Quase terminado!
Conclusão
