Ir para o conteúdo principal
iLive IKBC384S Disk Drive Replacement
O que você precisa
  1. iLive IKBC384S Disk Drive Replacement, Top Cover: passo 1, imagem 1 %32 iLive IKBC384S Disk Drive Replacement, Top Cover: passo 1, imagem 2 %32
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Disk Drive Replacement: passo 2, imagem 1 %32 iLive IKBC384S Disk Drive Replacement: passo 2, imagem 2 %32
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Disk Drive Replacement: passo 3, imagem 1 %32 iLive IKBC384S Disk Drive Replacement: passo 3, imagem 2 %32
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Disk Drive Replacement, Disk Drive: passo 4, imagem 1 %32 iLive IKBC384S Disk Drive Replacement, Disk Drive: passo 4, imagem 2 %32
    • Remove all four screws(13.5 mm in length) that are securing the device
  5. iLive IKBC384S Disk Drive Replacement: passo 5, imagem 1 %32 iLive IKBC384S Disk Drive Replacement: passo 5, imagem 2 %32
    • Remove both of the connected cords on the motherboard.
    • Also remove the flat ribbon cable that is connected to the motherboard.
    • Once you have removed all screws and cables connected to motherboard the disk drive can be easily removed
Conclusão
Allen Dover
Membro desde: 03/21/17
401 Reputação
Autoria de 4 guias
Equipe
Texas Tech, Team S46-G6, Bennett Spring 2017 Membro de Texas Tech, Team S46-G6, Bennett Spring 2017
TTU-BENNETT-S17S46G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 416
