Introdução
Sometimes when dropping the device, the back handle of the device can crack. Though it may not effect the functionality, it can be an inconvenience. Use this guide to replace this handle.
O que você precisa
Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
Pry off the mesh frame from the back side of the speaker with a plastic spudger until you hear a click noise when the clip is removed.
