Introdução
This guide instructs you to replace the screen in an iHome iPL8. The process includes using two sizes of screwdrivers.
O que você precisa
Turn the device over to access the bottom panel.
Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
Remove the four 6mm Phillips #2 screws.
Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
Pull out the green circuit board on the two corners.
The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
Look at the side of the device. You will see a green panel connecting to the black box by a white stripe.
Remove the four 2.5 mm Phillips #1 screws on the green panel.
Flip the green panel to reveal the front of the screen.
Uma outra pessoa concluiu este guia.
