Introdução
Use this guide to replace your iHome iP1's damaged or faulty 30-pin connector. This connector is located on the iPod/iPhone dock and is used to connect your Apple device to your iHome iP1.
O que você precisa
Rotate the iHome so that the speakers are facing you.
Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
4Comentários do guia
Where can you buy a new pin connector?
Where can I buy a new pin connector?
where can i buy new Board
