Ir para o conteúdo principal
iHome iH9 Infrared Receiver Replacement
O que você precisa
  1. iHome iH9 Infrared Receiver Replacement, Backup Batteries: passo 1, imagem 1 %32 iHome iH9 Infrared Receiver Replacement, Backup Batteries: passo 1, imagem 2 %32 iHome iH9 Infrared Receiver Replacement, Backup Batteries: passo 1, imagem 3 %32
    • Pull the tab towards you and lift up to remove the battery cover.
    • Remove the two AA batteries.
  2. iHome iH9 Infrared Receiver Replacement, Opening the iHome iH9: passo 2, imagem 1 %32
    • Unscrew the four 8mm Phillips #2 screws.
    • Unscrew the six 25mm Phillips #2 screws.
    • Reinstall the backup battery cover so it is out of the way.
  3. iHome iH9 Infrared Receiver Replacement: passo 3, imagem 1 %32 iHome iH9 Infrared Receiver Replacement: passo 3, imagem 2 %32 iHome iH9 Infrared Receiver Replacement: passo 3, imagem 3 %32
    • Pry the backplate up with a plastic opening tool between the back plate and the speaker grill.
    • Be careful when lifting the bottom plate up; there is a short white and orange 4-pin connector attached to its underside.
    • Lift the bottom plate up while making sure the connector remains attached.
  4. iHome iH9 Infrared Receiver Replacement: passo 4, imagem 1 %32 iHome iH9 Infrared Receiver Replacement: passo 4, imagem 2 %32 iHome iH9 Infrared Receiver Replacement: passo 4, imagem 3 %32
    • Use your hands to flip the backing plate away from you and rest it upside down on the iH9.
    • Unplug the white and orange 4-pin connector by pulling it in the direction of the wires.
    • Set the backing plate aside.
  5. iHome iH9 Infrared Receiver Replacement: passo 5, imagem 1 %32
    • Place the device so that the speaker grill is face down.
    • Remove the two 10mm Phillips #2 screws on interior sides of the speaker housings.
  6. iHome iH9 Infrared Receiver Replacement: passo 6, imagem 1 %32 iHome iH9 Infrared Receiver Replacement: passo 6, imagem 2 %32
    • Place the iH9 upside down.
    • Wires connect the core assembly to the housing; do not attempt to pull the core assembly completely out.
    • Using both hands, pull the housing siding away from the device while simultaneously lifting the motherboard and speaker assembly straight up.
    • Repeat for the other side.
  7. iHome iH9 Infrared Receiver Replacement: passo 7, imagem 1 %32
    • Stand the iH9 on its grill.
    • Separate the motherboard and speaker assembly by rocking it back and forth and pulling the assembly towards you.
    • Remove the small back panel.
  8. iHome iH9 Infrared Receiver Replacement: passo 8, imagem 1 %32 iHome iH9 Infrared Receiver Replacement: passo 8, imagem 2 %32 iHome iH9 Infrared Receiver Replacement: passo 8, imagem 3 %32
    • Firmly pull the wide 9-pin connector with black covering on the underside of the upper housing to unplug it.
    • Lay the housing and core assembly flat and close to each one another.
  9. iHome iH9 Infrared Receiver Replacement: passo 9, imagem 1 %32 iHome iH9 Infrared Receiver Replacement: passo 9, imagem 2 %32
    • Unplug the narrow 9-pin connector from the motherboard.
  10. iHome iH9 Infrared Receiver Replacement: passo 10, imagem 1 %32
    • Cut the zip tie holding the wires together with a wire cutter. The two sides of the device housing are now fully separated.
  11. iHome iH9 Infrared Receiver Replacement, Infrared Receiver: passo 11, imagem 1 %32
    • Set the iHome iH9 speaker and mother board assembly upright on the speaker grill.
    • Remove the grill ground wire by pulling in the direction of the wire.
    • The wire is located next to the left speaker housing.
  12. iHome iH9 Infrared Receiver Replacement: passo 12, imagem 1 %32
    • Unplug the 3 pin connector for the infrared sensor by pulling in the direction of the cable.
    • The wire is near the ground wire tab.
  13. iHome iH9 Infrared Receiver Replacement: passo 13, imagem 1 %32 iHome iH9 Infrared Receiver Replacement: passo 13, imagem 2 %32
    • Set the iH9 flat down with the solder side of the motherboard up and the speaker grill facing away.
    • With a nylon or metal spudger, pry the speaker grill up and forward from the two retaining flanges on the left and right speaker housings.
    • Set the speaker grill aside.
  14. iHome iH9 Infrared Receiver Replacement: passo 14, imagem 1 %32 iHome iH9 Infrared Receiver Replacement: passo 14, imagem 2 %32 iHome iH9 Infrared Receiver Replacement: passo 14, imagem 3 %32
    • Place the speaker covering front side down
    • Remove the one 8mm Philips Ph1 screw.
    • Gently lift the chipstraight up.
Conclusão
Charlie Ross
Membro desde: 02/01/15
345 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 8-39, Amido Winter 2015 Membro de Cal Poly, Team 8-39, Amido Winter 2015
CPSU-AMIDO-W15S8G39
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 387
