Introdução
You can use this guide to replace the buttons if they are broken or sticking. This guide requires you to remove the housing and unscrew a few parts in order to reach the button grouping.
It is best to find a flat, spacious working surface to keep the device level. Also, it helps to place the screws on a magnetic mat upon removal to keep them from rolling away.
O que você precisa
Pull the tab towards you and lift up to remove the battery cover.
Remove the two AA batteries.
Unscrew the four 8mm Phillips #2 screws.
Unscrew the six 25mm Phillips #2 screws.
Reinstall the backup battery cover so it is out of the way.
Turn the top cover plate upside-down and place it so the buttons are face down.
Remove the four 8mm Phillips #0 screws at the corners of the circuit board.
