Introdução
There are two scroll wheels on the iHome iH8BR. If you face the front of the iHome, the right scroll wheel controls the radio frequency while the left one controls the volume. These wheels can become worn down after heavy use and may need replacement.
Ferramentas
Peças
Nenhum componente especificado.
Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
Remove the battery cover and the batteries.
Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
The lower case can now be completely removed from the device!
Remove the four screws attaching the top of the case to the motherboard:
Two 9.5 mm Phillips #2 screws near the speaker grille.
Two 14.3 mm Phillips #2 screws that sit in recesses under the motherboard.
Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case.
Pulling outwards on the sides of the Upper Casing can help loosen the assembly.
If it seems too difficult to remove, chances are that a screw is still attached. Make sure you've removed every screw listed before proceeding to this step.
Pull the back adapter cover off.
Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case.
Two 6.4 mm Phillips #1 screws near the center of the adapter. These screws have built in washers.
One 4.0 mm Phillips #1 screw near the center of the adapter.
The iPod adapter should now be separate from the upper casing.
Remove the three 7.9 mm Phillips #1 screws holding the scroll wheel circuit board in place.
Repeat for the other circuit board.
3 outras pessoas concluíram este guia.
5 Comments
where do you get the scroll wheels to replace the bad ones?
I ended up opening the whole thing up, taking the scroll wheels off and cleaning them. I also blew into the encoders on the little circuit boards, and it fixed them. They’re behaving just like new now. Thanks! I think I could have gotten away with prying the wheels off from the outside without opening it up, but oh well. This was actually on an iH6 — the innards were very similar to this model.
