Ir para o conteúdo principal
iHome iH8BR Lower Case Replacement
O que você precisa
  1. iHome iH8BR Lower Case Replacement, Lower Case: passo 1, imagem 1 %32 iHome iH8BR Lower Case Replacement, Lower Case: passo 1, imagem 2 %32 iHome iH8BR Lower Case Replacement, Lower Case: passo 1, imagem 3 %32
    • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
    • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
    • Remove the battery cover and the batteries.
  2. iHome iH8BR Lower Case Replacement: passo 2, imagem 1 %32 iHome iH8BR Lower Case Replacement: passo 2, imagem 2 %32
    • Slide a spudger under the two front rubber pads to expose two hidden screws.
  3. iHome iH8BR Lower Case Replacement: passo 3, imagem 1 %32
    • Remove the following eight screws:
    • Four 15.1 mm Phillips #2 screws near the front of the device.
    • Four 12.7 mm Phillips #2 screws near the back of the device.
    • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
  4. iHome iH8BR Lower Case Replacement: passo 4, imagem 1 %32 iHome iH8BR Lower Case Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
    • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
    • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
    • The lower case can now be completely removed from the device!
Conclusão
cfredric
Membro desde: 04/17/13
25 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 12-33, Amido Spring 2013 Membro de Cal Poly, Team 12-33, Amido Spring 2013
CPSU-AMIDO-S13S12G33
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 555
