Ir para o conteúdo principal
iHome iH5 Charging Dock Replacement
O que você precisa
  1. iHome iH5 Charging Dock Replacement, Charging Dock: passo 1, imagem 1 %32
    • Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
  2. iHome iH5 Charging Dock Replacement: passo 2, imagem 1 %32
    • Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
  3. iHome iH5 Charging Dock Replacement: passo 3, imagem 1 %32
    • Remove the five 5/16 inch screws from the circuit board.
  4. iHome iH5 Charging Dock Replacement: passo 4, imagem 1 %32 iHome iH5 Charging Dock Replacement: passo 4, imagem 2 %32
    • Flip the circuit board over.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
    • There is on wire in the orange box.
    • There are two wires in the yellow box.
    • There are five wires in the green box.
  5. iHome iH5 Charging Dock Replacement: passo 5, imagem 1 %32
    • Remove the following four screws securing the iHome iH5 charging dock.
    • Use a #2 Phillips screwdriver to remove the four screws.
  6. iHome iH5 Charging Dock Replacement: passo 6, imagem 1 %32
    • Gently remove the charging dock from the iHome iH5 by pulling it up.
  7. iHome iH5 Charging Dock Replacement: passo 7, imagem 1 %32
    • Remove the final screws connecting the iH5 charging dock to the plastic holding platform
    • Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
  8. iHome iH5 Charging Dock Replacement: passo 8, imagem 1 %32
    • Replace the old iH5 charging dock with new iH5 charging dock.
Conclusão
Dustin Lamb
Membro desde: 03/13/14
103 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 949
