Ir para o conteúdo principal
iHome iH3L Clock Buttons Replacement
O que você precisa
  1. iHome iH3L Clock Buttons Replacement, Speakers: passo 1, imagem 1 %32 iHome iH3L Clock Buttons Replacement, Speakers: passo 1, imagem 2 %32 iHome iH3L Clock Buttons Replacement, Speakers: passo 1, imagem 3 %32
    • Locate all screws on the back of the iHome. Each screw can be located by the arrows on the iHome.
    • Two Countersunk 9.7 mm Phillips #2 screws in the middle.
    • Two 15.9 mm Phillips #2 screws.
    • Six 13.9 mm Phillips #2 screws.
    • Some screws are located under the black sticky pads. Gently remove the black sticky pads and it will expose the screws.
    • Two 11.8 mm Phillips #2 screws.
  2. iHome iH3L Clock Buttons Replacement: passo 2, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 2, imagem 2 %32
    • Remove all screws indicated in the previous step.
  3. iHome iH3L Clock Buttons Replacement: passo 3, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 3, imagem 2 %32 iHome iH3L Clock Buttons Replacement: passo 3, imagem 3 %32
    • Slowly tilt the bottom cover of the iHome up.
    • Do not yank the cover off, there is a wire connecting the cover to the circuit board.
    • Disconnect the wire just by pulling on the connector gently.
  4. iHome iH3L Clock Buttons Replacement: passo 4, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 4, imagem 2 %32
    • Disconnect the next connector pin after slowly opening the lid more.
  5. iHome iH3L Clock Buttons Replacement: passo 5, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 5, imagem 2 %32 iHome iH3L Clock Buttons Replacement: passo 5, imagem 3 %32
    • Disconnect the final connector pin series and carefully set your lid behind the body of the iHome.
    • The tiny speaker will not be disconnected for this repair, but you can easily remove it from the lid by means of a paperclip from the outside. While not necessary, this can help prevent damage to your device.
  6. iHome iH3L Clock Buttons Replacement: passo 6, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 6, imagem 2 %32
    • Remove the seven screws that are holding the motherboard in place:
    • Six 14 mm Phillips #2 screws.
    • One 14 mm Phillips #2 screw with two rubber washers on it.
  7. iHome iH3L Clock Buttons Replacement: passo 7, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 7, imagem 2 %32 iHome iH3L Clock Buttons Replacement: passo 7, imagem 3 %32
    • To remove the motherboard, gently lift up from opposite sides.
    • Be careful when lifting the motherboard. There are wires still connected to it on the backside.
  8. iHome iH3L Clock Buttons Replacement: passo 8, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 8, imagem 2 %32 iHome iH3L Clock Buttons Replacement: passo 8, imagem 3 %32
    • Carefully tilt the motherboard up from the front.
    • Disconnect the 8 connections by gently pulling on them. Starting from the front and work your way backwards.
    • All 8 connectors disconnected.
  9. iHome iH3L Clock Buttons Replacement: passo 9, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 9, imagem 2 %32
    • Unscrew the screws holding the speakers onto the body. One on each side:
    • Two 14.3 mm Phillips #2 screws.
  10. iHome iH3L Clock Buttons Replacement: passo 10, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 10, imagem 2 %32 iHome iH3L Clock Buttons Replacement: passo 10, imagem 3 %32
    • To remove the speakers from the iHome, gently lift up the back of the speaker and pull towards you. These are very secure so minor shaking may help release the speaker.
    • Repeat for the other side.
    • Be careful yanking on them, the speakers are connected together.
  11. iHome iH3L Clock Buttons Replacement, Clock Adjustment Buttons: passo 11, imagem 1 %32
    • At this point the buttons should be free of obstruction and easily accessible.
    • Unscrew the two 11.9 mm Phillips #2 screws that are holding the plastic buttons onto the body.
  12. iHome iH3L Clock Buttons Replacement: passo 12, imagem 1 %32 iHome iH3L Clock Buttons Replacement: passo 12, imagem 2 %32
    • Once the screws have been removed, simply lift the buttons up and out of their seat.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 275
