Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Set the IHome on a surface facing upward.
Locate the two screws on the docking station adapter.
Remove the following screws:
Two 10 mm Phillips #0
Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
Four 7 mm Phillips #0
Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
Lift up the circuit board that has become loose.
Pull out the adapter, and replace it with the new one.
Uma outra pessoa concluiu este guia.
