Ir para o conteúdo principal
iHome iH27B iPod Adapter Replacement
O que você precisa
  1. iHome iH27B iPod Adapter Replacement, Adapter: passo 1, imagem 1 %32
    • Set the IHome on a surface facing upward.
    • Locate the two screws on the docking station adapter.
    • Remove the following screws:
    • Two 10 mm Phillips #0
  2. iHome iH27B iPod Adapter Replacement: passo 2, imagem 1 %32
    • Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
    • The adapter will still be connected with wires, so make sure not to pull too hard.
  3. iHome iH27B iPod Adapter Replacement: passo 3, imagem 1 %32 iHome iH27B iPod Adapter Replacement: passo 3, imagem 2 %32 iHome iH27B iPod Adapter Replacement: passo 3, imagem 3 %32
    • Four 7 mm Phillips #0
    • Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
  4. iHome iH27B iPod Adapter Replacement: passo 4, imagem 1 %32 iHome iH27B iPod Adapter Replacement: passo 4, imagem 2 %32
    • Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
    • Do this slowly. Be careful not to damage the wires
    • Lift up the circuit board that has become loose.
  5. iHome iH27B iPod Adapter Replacement: passo 5, imagem 1 %32
    • Pull out the adapter, and replace it with the new one.
Conclusão
Uma outra pessoa concluiu este guia.
John Kraemer
Membro desde: 10/09/12
76 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 3-21, Amido Fall 2012 Membro de Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Membros
Autoria de 9 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 2,388
