Ir para o conteúdo principal
iHome iH27B AV circuit board Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. iHome iH27B AV circuit board Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B AV circuit board Replacement: passo 2, imagem 1 %32 iHome iH27B AV circuit board Replacement: passo 2, imagem 2 %32 iHome iH27B AV circuit board Replacement: passo 2, imagem 3 %32
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B AV circuit board Replacement: passo 3, imagem 1 %32
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B AV circuit board Replacement: passo 4, imagem 1 %32
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B AV circuit board Replacement: passo 5, imagem 1 %32
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B AV circuit board Replacement, AV circuit board: passo 6, imagem 1 %32
    • Two 10 mm Phillips #0
  7. iHome iH27B AV circuit board Replacement: passo 7, imagem 1 %32
    • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
Conclusão
John Kraemer
Membro desde: 10/09/12
76 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 3-21, Amido Fall 2012 Membro de Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 230
