Ir para o conteúdo principal
iHome iBT84 Motherboard Replacement
O que você precisa
  1. iHome iBT84 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 iHome iBT84 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
    • Use a Philip's screwdriver to take the screws out of the cover.
  2. iHome iBT84 Motherboard Replacement: passo 2, imagem 1 %32 iHome iBT84 Motherboard Replacement: passo 2, imagem 2 %32
    • Once the screws are all out, the cover should come off revealing the motherboard.
  3. iHome iBT84 Motherboard Replacement: passo 3, imagem 1 %32 iHome iBT84 Motherboard Replacement: passo 3, imagem 2 %32 iHome iBT84 Motherboard Replacement: passo 3, imagem 3 %32
    • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
    • Once that is done, the motherboard can be taken out. May require some wiggling.
    • Make sure none of the wires are damaged and that they are all connected.
  4. iHome iBT84 Motherboard Replacement: passo 4, imagem 1 %32
    • The connections shown here can be taken off by pulling on the white plastic connector piece.
    • The same can be said about the white, paper like, connectors. Pull on them gently.
    • Once all connections are apart, the motherboard is safe to be replaced.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 952
