Ir para o conteúdo principal
iHome iBT16 Motherboard Replacement
O que você precisa
  1. iHome iBT16 Motherboard Replacement, Base Plate: passo 1, imagem 1 %32 iHome iBT16 Motherboard Replacement, Base Plate: passo 1, imagem 2 %32
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Motherboard Replacement: passo 2, imagem 1 %32 iHome iBT16 Motherboard Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome iBT16 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 iHome iBT16 Motherboard Replacement, Motherboard: passo 3, imagem 2 %32 iHome iBT16 Motherboard Replacement, Motherboard: passo 3, imagem 3 %32
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
  4. iHome iBT16 Motherboard Replacement: passo 4, imagem 1 %32 iHome iBT16 Motherboard Replacement: passo 4, imagem 2 %32
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
  5. iHome iBT16 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the plastic cover from the power switch actuator on the motherboard.
Conclusão
Joseph Hazel
Membro desde: 03/24/17
353 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,155
