Introdução
In this guide, the reader will be stepped through the process of removing and replacing the base panel on the iHome iBT16. This is a prerequisite guide to most replacement guides, due to it being the access to the motherboard.
O que você precisa
Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
Quase terminado!
Conclusão
