Ir para o conteúdo principal
iHome iBT16 Base Plate Replacement
O que você precisa
  1. iHome iBT16 Base Plate Replacement, Base Plate: passo 1, imagem 1 %32 iHome iBT16 Base Plate Replacement, Base Plate: passo 1, imagem 2 %32
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Base Plate Replacement: passo 2, imagem 1 %32 iHome iBT16 Base Plate Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
Conclusão
Ryan Edwards
Membro desde: 03/21/17
331 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 229
