Ir para o conteúdo principal
iHome iAVS16 Motherboard Replacement
O que você precisa
  1. iHome iAVS16 Motherboard Replacement, Power Board: passo 1, imagem 1 %32 iHome iAVS16 Motherboard Replacement, Power Board: passo 1, imagem 2 %32 iHome iAVS16 Motherboard Replacement, Power Board: passo 1, imagem 3 %32
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Motherboard Replacement: passo 2, imagem 1 %32 iHome iAVS16 Motherboard Replacement: passo 2, imagem 2 %32 iHome iAVS16 Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Motherboard Replacement: passo 3, imagem 1 %32 iHome iAVS16 Motherboard Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Motherboard Replacement: passo 4, imagem 1 %32 iHome iAVS16 Motherboard Replacement: passo 4, imagem 2 %32 iHome iAVS16 Motherboard Replacement: passo 4, imagem 3 %32
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 Motherboard Replacement, LCD (Display): passo 5, imagem 1 %32 iHome iAVS16 Motherboard Replacement, LCD (Display): passo 5, imagem 2 %32 iHome iAVS16 Motherboard Replacement, LCD (Display): passo 5, imagem 3 %32
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 Motherboard Replacement: passo 7, imagem 1 %32 iHome iAVS16 Motherboard Replacement: passo 7, imagem 2 %32 iHome iAVS16 Motherboard Replacement: passo 7, imagem 3 %32
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
  8. iHome iAVS16 Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Flip up the back of the device encasing the motherboard.
  9. iHome iAVS16 Motherboard Replacement: passo 9, imagem 1 %32 iHome iAVS16 Motherboard Replacement: passo 9, imagem 2 %32 iHome iAVS16 Motherboard Replacement: passo 9, imagem 3 %32
    Comprar
    • Using tweezers, unplug the white, red, and blue connectors from the motherboard by pulling each out.
  10. iHome iAVS16 Motherboard Replacement: passo 10, imagem 1 %32
    • Carefully unplug the ribbon cable, making sure not to rip it.
Conclusão
James Hoye
Membro desde: 10/25/19
97 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 Membro de UMass Dartmouth, Team S1-G7, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G7
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 227
