Ir para o conteúdo principal
iHip Fold-up Portable Speaker Back Cover Removal
O que você precisa
  1. iHip Fold-up Portable Speaker Back Cover Removal, Removing the battery case cover: passo 1, imagem 1 %32
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: passo 2, imagem 1 %32 iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: passo 2, imagem 2 %32 iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: passo 2, imagem 3 %32
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker Back Cover Removal, Removing the screws: passo 3, imagem 1 %32 iHip Fold-up Portable Speaker Back Cover Removal, Removing the screws: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker Back Cover Removal, Removing the back cover: passo 4, imagem 1 %32 iHip Fold-up Portable Speaker Back Cover Removal, Removing the back cover: passo 4, imagem 2 %32
    • Remove the back cover carefully; there are many wires that connect it to the device.
Conclusão
Cristina Garcia
Membro desde: 10/13/14
301 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 3-4, Benson Fall 2014 Membro de Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 298
