Introdução
This guide will show you how to replace the wrist band on the iHealth Edge. You must take the device and remove the elastic band. This will expose the iHealth Edge and you will be able to put the new band on.
Pull the elastic band away from the device as shown. You will need to use one hand to support the device and pull the elastic band with the other at about a 45 degree angle.
Quase terminado!
This guide will show you how to replace the arm band.
Conclusão
