Ir para o conteúdo principal
iHealth Edge Band Replacement
  1. iHealth Edge Band Replacement, Band: passo 1, imagem 1 %32
    • Pull the elastic band away from the device as shown. You will need to use one hand to support the device and pull the elastic band with the other at about a 45 degree angle.
  2. iHealth Edge Band Replacement: passo 2, imagem 1 %32
    • Pull the elastic band away from the device, you should now have the device with no band as shown.
  3. iHealth Edge Band Replacement: passo 3, imagem 1 %32 iHealth Edge Band Replacement: passo 3, imagem 2 %32
    • Place the elastic band into the channel in the side of the device shown in the picture. The band will pull into the channel and lock into place.
  4. iHealth Edge Band Replacement: passo 4, imagem 1 %32
    • After pulling the band into place the guide is now complete. Your iHealth Edge should be ready for use.
Conclusão
This guide will show you how to replace the arm band.
Equipe
IUPUI, Team S1-G4, Freund Fall 2017 Membro de IUPUI, Team S1-G4, Freund Fall 2017
IUPUI-FREUND-F17S1G4
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 381
