Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Box should include:
Set of screws/driver
Metal rods
Honeycomb Base/Feet
Main stand (back/sides)
Two large, one small foldable shelf insert
Two large, one small black rectangular insert
"You can fix it" panel and iFixit topper (not pictured)
The three angled supports fit into the two rectangular supports.
Place the fully constructed honeycomb base into the display.
Fit “You can fix it” panel over front of honeycomb base
“You can fix it” panel sides fit INSIDE of base walls
Use screws to fasten
Build bottom shelf, using one of two larger foldable shelves
Tabs fit together, fit side tabs along back, then fold over and secure
Install two metal support for middle shelf
Metal rods fit into provided holes
Fit bottom shelf into bottom shelf slots cut into back of display
Tabs go out the back and then back in towards the front
Lay black shelf insert into shelf
Fit screws together to hold shelf in place
Repeat for middle and top shelves
Top shelf and insert are smaller than bottom and middle shelves
Fold top section down to make holes match
Align iFixit sign and install using screws
