Ir para o conteúdo principal
  1. iFixit Side Stack Retail Display Assembly, Empty Box Components: passo 1, imagem 1 %32
    • Box should include:
    • Set of screws/driver
    • Metal rods
    • Honeycomb Base/Feet
    • Main stand (back/sides)
    • Two large, one small foldable shelf insert
    • Two large, one small black rectangular insert
    • "You can fix it" panel and iFixit topper (not pictured)
  2. iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: passo 2, imagem 1 %32 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: passo 2, imagem 2 %32 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: passo 2, imagem 3 %32
    • The three angled supports fit into the two rectangular supports.
    • Place the fully constructed honeycomb base into the display.
  3. iFixit Side Stack Retail Display Assembly, "You can fix it": passo 3, imagem 1 %32 iFixit Side Stack Retail Display Assembly, "You can fix it": passo 3, imagem 2 %32 iFixit Side Stack Retail Display Assembly, "You can fix it": passo 3, imagem 3 %32
    • Fit “You can fix it” panel over front of honeycomb base
    • “You can fix it” panel sides fit INSIDE of base walls
    • Use screws to fasten
  4. iFixit Side Stack Retail Display Assembly, Build Shelf Insert: passo 4, imagem 1 %32 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: passo 4, imagem 2 %32 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: passo 4, imagem 3 %32
    • Build bottom shelf, using one of two larger foldable shelves
    • Tabs fit together, fit side tabs along back, then fold over and secure
  5. iFixit Side Stack Retail Display Assembly, Install Metal Supports: passo 5, imagem 1 %32 iFixit Side Stack Retail Display Assembly, Install Metal Supports: passo 5, imagem 2 %32
    • Install two metal support for middle shelf
    • Metal rods fit into provided holes
  6. iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: passo 6, imagem 1 %32 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: passo 6, imagem 2 %32 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: passo 6, imagem 3 %32
    • Fit bottom shelf into bottom shelf slots cut into back of display
    • Tabs go out the back and then back in towards the front
    • Lay black shelf insert into shelf
    • Fit screws together to hold shelf in place
    • Repeat for middle and top shelves
    • Top shelf and insert are smaller than bottom and middle shelves
  7. iFixit Side Stack Retail Display Assembly, Fold Sides into Honeycomb Base: passo 7, imagem 1 %32
    • Like so.
    • (Go Angels!)
  8. iFixit Side Stack Retail Display Assembly, iFixt Header Sign: passo 8, imagem 1 %32 iFixit Side Stack Retail Display Assembly, iFixt Header Sign: passo 8, imagem 2 %32
    • Fold top section down to make holes match
    • Align iFixit sign and install using screws
Conclusão
Eric Essen
Membro desde: 04/06/2010
17.348 Reputação
8 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
146 Membros
15.598 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 187
