Ir para o conteúdo principal
iFixit Precision Bit Driver Reassembly
O que você precisa
  1. iFixit Precision Bit Driver Reassembly, How to reinstall the bearing cap: passo 1, imagem 1 %32 iFixit Precision Bit Driver Reassembly, How to reinstall the bearing cap: passo 1, imagem 2 %32 iFixit Precision Bit Driver Reassembly, How to reinstall the bearing cap: passo 1, imagem 3 %32
    • Unscrew the center of the barrel
    • Note: Assembly utilizes threat locker. You may need tools to unscrew. Use a small piece of duct tape on the smooth part to protect the aluminum.
    • Use pliers on the duct tape, and an adjustable wrench on the flat of the knurled part near the bottom of the screw driver to create leverage to unscrew the barrel.
    Pergunte ao FixBot
    Comentar
  2. iFixit Precision Bit Driver Reassembly: passo 2, imagem 1 %32 iFixit Precision Bit Driver Reassembly: passo 2, imagem 2 %32 iFixit Precision Bit Driver Reassembly: passo 2, imagem 3 %32
    • Next use a 2.5mm hex key with a long shaft such that it fits all the way through the top half of the screw driver.
    • Insert the bearing/top assembly onto the hex key, and begin tightening the bearing assembly into the screwdriver.
    • Note: threadlocker should not be necessary here as there is an O ring that is responsible for maintaining the thread loading
    Pergunte ao FixBot
    Comentar
  3. iFixit Precision Bit Driver Reassembly: passo 3, imagem 1 %32
    • Screw the two halves of the barrel back together.
    • While not necessary, some thread locker can be applied to the threads on the upper half of the barrel to prevent the two halves from separating. Be sure to use non-permanent thread locker in case you need to do this again in the future!
    Pergunte ao FixBot
    Comentar
  4. iFixit Precision Bit Driver Reassembly: passo 4, imagem 1 %32
    • Voila, enjoy your screw driver.
    Pergunte ao FixBot
    Comentar
Conclusão
There are other ways to do this, such as the floss trick. But if you have the tools lying around here's the proper way to reassemble your iFixit Precision screwdriver!
Ricky H
Membro desde: 04/13/12
199 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 49
Últimos 30 dias: 128
Ao todo: 1,871
