Ir para o conteúdo principal
iFixit 26 Bit Driver Kit Technique for Removing Bits
O que você precisa
  1. iFixit 26 Bit Driver Kit Technique for Removing Bits, iFixit 26 Bit Driver Kit Technique for Removing Bits: passo 1, imagem 1 %32
    • Note how challenging it is to remove a required bit from the kit. Argh!
  2. iFixit 26 Bit Driver Kit Technique for Removing Bits: passo 2, imagem 1 %32
    • Find yourself a rubber band...
  3. iFixit 26 Bit Driver Kit Technique for Removing Bits: passo 3, imagem 1 %32
    • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
  4. iFixit 26 Bit Driver Kit Technique for Removing Bits: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
Conclusão
49 outras pessoas executaram este guia.
aaronmiller
Membro desde: 08/28/11
1.394 Reputação
Autoria de 1 guia
2Comentários do guia
I want to order the 26 bit driver kit technique for removing bits
clement mEnThChEl - Responder
I just use the included bit driver. Once removed, reverse it and I am ready to go!
P.S. Anyone got a guide on how to fix the hinge. Spring is loose and the bit tray is out.
Harold - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 49
Ao todo: 5,808
