Ir para o conteúdo principal
iDevices iGrill Probe Replacement
O que você precisa
  1. iDevices iGrill Probe Replacement, Probes: passo 1, imagem 1 %32
    • Remove the back plastic cover from the device; this should allow you access to the batteries.
  2. iDevices iGrill Probe Replacement: passo 2, imagem 1 %32
    • Remove the batteries from the device.
  3. iDevices iGrill Probe Replacement: passo 3, imagem 1 %32 iDevices iGrill Probe Replacement: passo 3, imagem 2 %32
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm screws using a Phillips screwdriver. The screws are located on the left side of the internal cover.
    • Remove the accompanying plastic tabs under the screws.
    • Gently pull off the back cover from the device.
  4. iDevices iGrill Probe Replacement: passo 4, imagem 1 %32 iDevices iGrill Probe Replacement: passo 4, imagem 2 %32 iDevices iGrill Probe Replacement: passo 4, imagem 3 %32
    • If you have not removed the 2 silver-colored screws; you must remove them now.
    • Remove the metal terminals from the battery slot closest you.
    • Pull the remaining metal terminals out of their slots. Position them such that when removing the internal cover they will not be caught.
    • Remove the internal cover.
  5. iDevices iGrill Probe Replacement: passo 5, imagem 1 %32
    • After the internal plastic case has been removed, you will have access to the probe contacts.
    • You should then insert the probes to check their connection to the probe terminals.
  6. iDevices iGrill Probe Replacement: passo 6, imagem 1 %32
    • Using a pair of tweezers, bend the probe contacts back in place. The tweezers will touch the probe terminals when inserted.
Conclusão
Michelle Nguyen
Membro desde: 02/16/16
204 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-4, Harley Spring 2016 Membro de IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,047
