Ir para o conteúdo principal
iDevices iGrill Power Delivery Wires and Springs Replacement
O que você precisa
  1. iDevices iGrill Power Delivery Wires and Springs Replacement, Power Delivery Wires and Springs: passo 1, imagem 1 %32
    • Place the front screen of the device on a flat surface, this allows access to the back cover. Remove the back cover from the device to access the batteries.
  2. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 2, imagem 1 %32
    • Remove the batteries from the device, allowing you to access the screws necessary for removal of the back panel.
  3. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 3, imagem 1 %32 iDevices iGrill Power Delivery Wires and Springs Replacement: passo 3, imagem 2 %32
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm Phillips screws from the left side of the internal cover.
  4. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 4, imagem 1 %32
    • Gently and slowly pull the back cover off of the iGrill, exposing the power cables to the motherboard.
  5. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 5, imagem 1 %32 iDevices iGrill Power Delivery Wires and Springs Replacement: passo 5, imagem 2 %32
    • Gently pull the metal terminals to the batteries out of their plastic holders.
    • Position the metal terminals such that you will be able to pull the plastic component that holds the batteries away from the motherboard.
    • Remove the internal cover from the device.
  6. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 6, imagem 1 %32
    • After you have peeled back the rear plastic covering, you will have access to the motherboard.
  7. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 7, imagem 1 %32
    • From here, you will have access to both the metal terminals of the power transfer wires and the soldering points of the power transfer wires to the motherboard.
    • If any of these connections have been broken, repair them with a solder and soldering wire.
Conclusão
Uma outra pessoa concluiu este guia.
Kyle McElyea
Membro desde: 02/16/16
259 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-4, Harley Spring 2016 Membro de IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 42
Ao todo: 495
