Ir para o conteúdo principal
iDeaUSA CT8 Motherboard Replacement
O que você precisa
  1. iDeaUSA CT8 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 iDeaUSA CT8 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 iDeaUSA CT8 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Place the tablet on a flat surface, facing upwards.
    • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
    • Being cautious of the wire connecting the speaker and the motherboard, place the front and back portion of the tablet close in proximity.
  2. iDeaUSA CT8 Motherboard Replacement: passo 2, imagem 1 %32 iDeaUSA CT8 Motherboard Replacement: passo 2, imagem 2 %32 iDeaUSA CT8 Motherboard Replacement: passo 2, imagem 3 %32
    • Locate the five 3.5 mm black screws on the motherboard.
    • Use the #00 Phillips screwdriver to remove the screws, place them in an appropriate location.
  3. iDeaUSA CT8 Motherboard Replacement: passo 3, imagem 1 %32
    • Carefully peel off the tape covering the circuit boards and blue ribbons. The tape can be disposed or saved for reuse.
  4. iDeaUSA CT8 Motherboard Replacement: passo 4, imagem 1 %32 iDeaUSA CT8 Motherboard Replacement: passo 4, imagem 2 %32 iDeaUSA CT8 Motherboard Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • After removing the tape, two blue ribbon wires can now be accessed. To disconnect, gently lift up the plastic ZIF tabs covering the wires.
    • Upon lifting the tab, the ribbons can now be safely pulled out of their connections.
    • To avoid breaking or damaging the plastic ZIF tabs, it is recommended to use tweezers.
  5. iDeaUSA CT8 Motherboard Replacement: passo 5, imagem 1 %32
    • Locate the two wires connecting the speaker to the motherboard.
    • Use a soldering iron to desolder the red and black wires from their sockets.
    • Solder the speaker wires back in place during reassembly.
  6. iDeaUSA CT8 Motherboard Replacement: passo 6, imagem 1 %32 iDeaUSA CT8 Motherboard Replacement: passo 6, imagem 2 %32
    • Disconnect the wires connecting the battery to the motherboard.
    • Start from the sides and gently wiggle the connection out until it;s loose enough to pull.
  7. iDeaUSA CT8 Motherboard Replacement: passo 7, imagem 1 %32 iDeaUSA CT8 Motherboard Replacement: passo 7, imagem 2 %32
    • Pull out and free the motherboard from its position.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 146
