Ir para o conteúdo principal
iDea USA CT702 Microphone Replacement
O que você precisa
  1. iDea USA CT702 Microphone Replacement, Microphone: passo 1, imagem 1 %32
    • Place the tablet face up with portholes facing you.
  2. iDea USA CT702 Microphone Replacement: passo 2, imagem 1 %32 iDea USA CT702 Microphone Replacement: passo 2, imagem 2 %32
    • Use a fingernail, or a plastic opening tool to gently pry the black panel around the portholes.
    • Be gentle and take your time. Excessive force could damage the device.
  3. iDea USA CT702 Microphone Replacement: passo 3, imagem 1 %32 iDea USA CT702 Microphone Replacement: passo 3, imagem 2 %32 iDea USA CT702 Microphone Replacement: passo 3, imagem 3 %32
    • Use your fingers to pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
  4. iDea USA CT702 Microphone Replacement: passo 4, imagem 1 %32
    • Once the back is off, position the tablet as shown and be sure to warm your soldering iron.
  5. iDea USA CT702 Microphone Replacement: passo 5, imagem 1 %32
    • Place tip of the soldering iron on the end of the wire to break connection.
    • Remember to use proper safety precautions when soldering.
  6. iDea USA CT702 Microphone Replacement: passo 6, imagem 1 %32
    • Grip the new microphone with tweezers and place in the slot.
    • Solder the new connections while using tweezers to hold the speaker steady.
Conclusão
Benton Gray
Membro desde: 03/11/15
201 Reputação
Autoria de 2 guias
Equipe
Colorado Springs, Team 4-7, Panko Spring 2015 Membro de Colorado Springs, Team 4-7, Panko Spring 2015
UCCS-PANKO-S15S4G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 116
