Ir para o conteúdo principal
iDea USA CT702 Battery Replacement
O que você precisa
  1. iDea USA CT702 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Face the tablet with portholes facing you.
  2. iDea USA CT702 Battery Replacement: passo 2, imagem 1 %32
    • Use a fingernail or a plastic opening tool to gently pry the black panel around the portholes.
    • Be gentle and take your time.
  3. iDea USA CT702 Battery Replacement: passo 3, imagem 1 %32 iDea USA CT702 Battery Replacement: passo 3, imagem 2 %32 iDea USA CT702 Battery Replacement: passo 3, imagem 3 %32
    • Use your fingers to remove the rest of the back. Slowly apply pressure from each side to detach each clip connection.
  4. iDea USA CT702 Battery Replacement: passo 4, imagem 1 %32 iDea USA CT702 Battery Replacement: passo 4, imagem 2 %32
    • Separate the battery from the device.
    • Slowly use your thumb and forefingers to pry open each corner.
    • Be aware of the adhesive on the bottom of the battery. Remove with care to keep battery intact.
  5. iDea USA CT702 Battery Replacement: passo 5, imagem 1 %32
    • Carefully peel off tape around the top of the battery.
    • Slowly use your fingernail to lift the tape off of the battery. Dispose of the tape or save it for reuse.
  6. iDea USA CT702 Battery Replacement: passo 6, imagem 1 %32 iDea USA CT702 Battery Replacement: passo 6, imagem 2 %32 iDea USA CT702 Battery Replacement: passo 6, imagem 3 %32
    • Disconnect the battery using the soldering iron.
    • Remember to use proper safety precautions when soldering. Solder from the side and do not breathe the smoke in.
    • Make sure the soldering iron is on the highest heat for 5 minutes before starting.
    • Start with the red wire, and gently touch the tip of the iron onto the connection.
    • Move to the yellow wire after the red.
    • Move to the black wire after the yellow.
  7. iDea USA CT702 Battery Replacement: passo 7, imagem 1 %32
    • Remove the battery completely. Dispose of the defective battery properly at a recycling center.
  8. iDea USA CT702 Battery Replacement: passo 8, imagem 1 %32
    • Put the new battery in place
    • Make sure the corners are inside of the white shell.
  9. iDea USA CT702 Battery Replacement: passo 9, imagem 1 %32 iDea USA CT702 Battery Replacement: passo 9, imagem 2 %32
    • Solder the new battery.
    • Start with the black wire and solder to the nearest connection.
    • Move to the yellow wire and solder to the middle connection.
    • End with the red wire and solder to the farthest connection away.
  10. iDea USA CT702 Battery Replacement: passo 10, imagem 1 %32 iDea USA CT702 Battery Replacement: passo 10, imagem 2 %32
    • Re-tape the battery at the top.
    • Make sure the solder has cooled before taping.
    • Tape the corners in place, onto the shell.
    • To replace back cover, follow the first three steps in reverse order.
Conclusão
To reassemble your device, Start from step 9 and work backwards.
Benton Gray
Membro desde: 03/11/15
201 Reputação
Autoria de 2 guias
Equipe
Colorado Springs, Team 4-7, Panko Spring 2015 Membro de Colorado Springs, Team 4-7, Panko Spring 2015
UCCS-PANKO-S15S4G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 605
