Introdução
For this repair guide, the rear facing camera on the iDea USA CT 1020 will be addressed. The camera can easily become damaged or cracked if the tablet is mishandled by the user, or the camera can simply stop working. Once the backing plate is removed from the tablet and the rear camera is located on the motherboard, the removal process is simple. The electrical ribbon running from the camera goes to an electrical connector, and once the connector is unsnapped, the camera is free to be removed.
  1. First, power down the tablet to avoid the chance of electrical shock or damaging the machine during repair work
    • First, power down the tablet to avoid the chance of electrical shock or damaging the machine during repair work
    • Place the tablet on a clean surface with the screen down
  2. Remove the back plastic casing of the tablet by releasing the plastic clips with a plastic opening tool or a spudger. Be cautious and take your time here; the plastic clips are quite fragile.
    • Remove the back plastic casing of the tablet by releasing the plastic clips with a plastic opening tool or a spudger.
      • Be cautious and take your time here; the plastic clips are quite fragile.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Use a plastic opening tool or spudger to lift and release the camera assembly ZIF tab.
    • Use a plastic opening tool or spudger to lift and release the camera assembly ZIF tab.
    • Gently pull the ribbon cable free.
  5. The camera is held in place by adhesive material on the back of the camera To complete removal, peel the camera off the mother board
    • The camera is held in place by adhesive material on the back of the camera
    • To complete removal, peel the camera off the mother board
Conclusão
Uma outra pessoa concluiu este guia.
David Lawrence
109 reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G3, Freund Spring 2018 Membro de IUPUI, Team S1-G3, Freund Spring 2018
IUPUI-FREUND-S18S1G3
3 Membros
4 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 50
