Ir para o conteúdo principal
iDea USA CT 1020 Front & Rear Camera Assembly Replacement
O que você precisa
  1. iDea USA CT 1020 Front & Rear Camera Assembly Replacement, Front & Rear Camera Assembly: passo 1, imagem 1 %32
    • First, power down the tablet to avoid the chance of electrical shock or damaging the machine during repair work
    • Place the tablet on a clean surface with the screen down
  2. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: passo 2, imagem 1 %32 iDea USA CT 1020 Front & Rear Camera Assembly Replacement: passo 2, imagem 2 %32
    • Remove the back plastic casing of the tablet by releasing the plastic clips with a plastic opening tool or a spudger.
    • Be cautious and take your time here; the plastic clips are quite fragile.
  3. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool or spudger to lift and release the camera assembly ZIF tab.
    • Gently pull the ribbon cable free.
  4. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: passo 4, imagem 1 %32 iDea USA CT 1020 Front & Rear Camera Assembly Replacement: passo 4, imagem 2 %32
    • The camera is held in place by adhesive material on the back of the camera
    • To complete removal, peel the camera off the mother board
Conclusão
Uma outra pessoa concluiu este guia.
David Lawrence
Membro desde: 01/22/18
109 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G3, Freund Spring 2018 Membro de IUPUI, Team S1-G3, Freund Spring 2018
IUPUI-FREUND-S18S1G3
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 99
