Ir para o conteúdo principal
iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement
O que você precisa
  1. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement, Battery: passo 1, imagem 1 %32
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 2, imagem 1 %32
    • Lift the battery out of the computer.
  3. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement, Rear Display Bezel: passo 3, imagem 1 %32 iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement, Rear Display Bezel: passo 3, imagem 2 %32
    • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  4. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 4, imagem 1 %32 iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 4, imagem 2 %32
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  5. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 5, imagem 1 %32
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  6. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 6, imagem 1 %32 iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 6, imagem 2 %32
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  7. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 7, imagem 1 %32
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  8. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 8, imagem 1 %32
    • Lift the rear bezel off the display assembly.
  9. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement, LCD: passo 9, imagem 1 %32 iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement, LCD: passo 9, imagem 2 %32
    • Close the display.
    • Remove the several pieces of tape securing the thin metal LCD cover to the display.
    • Carefully remove the piece of foil tape covering the display data cable connection.
  10. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 10, imagem 1 %32 iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 10, imagem 2 %32
    • Remove the Phillips screw near the right display hinge.
    • Use the tip of a spudger to remove the small spacer under the screw you just removed.
  11. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 11, imagem 1 %32
    • Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges.
    • Leave the tape attached to the thin steel LCD cover.
  12. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 12, imagem 1 %32 iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 12, imagem 2 %32
    • Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
  13. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 13, imagem 1 %32
    • Carefully remove the thin steel LCD cover.
  14. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 14, imagem 1 %32
    • Disconnect the display data cable by pulling the cable away from the socket on the LCD.
  15. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 15, imagem 1 %32
    • Remove the strip of yellow tape securing the display data cable to the metal LCD frame.
  16. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 16, imagem 1 %32 iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 16, imagem 2 %32
    • Disconnect the backlight cable from the inverter.
    • It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
  17. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 17, imagem 1 %32
    • Lift the LCD out of the display assembly.
    • It may be helpful to press the latch release button and open your display slightly to push the LCD out of the display assembly.
  18. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement, Display Inverter: passo 18, imagem 1 %32
    • Remove the two pieces of yellow tape covering the inverter/AirPort cables.
  19. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 19, imagem 1 %32
    • Disconnect the inverter cable by pulling its connector away from the socket on the inverter board.
    • The inverter board is a very thin and delicate circuit board that is easily broken. Use caution.
    • This connector tends to stick in its socket. It is helpful to push the connector with the tip of a spudger through the two small holes in the top of the socket while pulling the connector away from the socket.
    • Make sure to grasp the inverter cabling by the black tape and not the individual wires. Pulling the wires themselves will surely damage the inverter cable.
  20. iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 20, imagem 1 %32 iBook G4 14" 933 MHz-1.33 GHz Display Inverter Replacement: passo 20, imagem 2 %32
    • Insert the flat end of a spudger under the middle of the inverter board.
    • Slide the spudger to the far left and right edges to separate the inverter board from the adhesive securing it to the front bezel.
    • Remove the inverter board.
Conclusão
3 outras pessoas executaram este guia.
Documentos anexados
Um comentário
brilliant guide
carl - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 5,974
