Introdução
Tripped over your power cord? At least you don't have to replace the entire logic board.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
69 outras pessoas concluíram este guia.
