Introdução
Charges battery and connects battery to logic board.
O que você precisa
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
4 outras pessoas executaram este guia.
