Ir para o conteúdo principal
iBook G4 14" 1.42 GHz Rear Display Bezel Replacement
O que você precisa
  1. iBook G4 14" 1.42 GHz Rear Display Bezel Replacement, Battery: passo 1, imagem 1 %32
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 1.42 GHz Rear Display Bezel Replacement: passo 2, imagem 1 %32
    • Lift the battery out of the computer.
  3. iBook G4 14" 1.42 GHz Rear Display Bezel Replacement, Rear Display Bezel: passo 3, imagem 1 %32 iBook G4 14" 1.42 GHz Rear Display Bezel Replacement, Rear Display Bezel: passo 3, imagem 2 %32
    • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  4. iBook G4 14" 1.42 GHz Rear Display Bezel Replacement: passo 4, imagem 1 %32 iBook G4 14" 1.42 GHz Rear Display Bezel Replacement: passo 4, imagem 2 %32
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  5. iBook G4 14" 1.42 GHz Rear Display Bezel Replacement: passo 5, imagem 1 %32
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  6. iBook G4 14" 1.42 GHz Rear Display Bezel Replacement: passo 6, imagem 1 %32 iBook G4 14" 1.42 GHz Rear Display Bezel Replacement: passo 6, imagem 2 %32
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  7. iBook G4 14" 1.42 GHz Rear Display Bezel Replacement: passo 7, imagem 1 %32
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  8. iBook G4 14" 1.42 GHz Rear Display Bezel Replacement: passo 8, imagem 1 %32
    • Lift the rear bezel off the display assembly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 2,036
