Introdução
Replace a broken LCD/Backlight with the display still attached to your iBook.
O que você precisa
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Close the display.
Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
Remove the large piece of tape near the right display hinge.
11 outras pessoas executaram este guia.
