Introdução
Replace a faulty display inverter with the display attached to your iBook.
Ferramentas
Peças
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Close the display.
Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
Remove the large piece of tape near the right display hinge.
Remove the pieces of tape holding the inverter and the inverter cables to the clutch hinges.
Uma outra pessoa concluiu este guia.
