Introdução
Remove your rear display bezel to access your display's internals.
O que você precisa
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
3 outras pessoas executaram este guia.
