Ir para o conteúdo principal
iBook G3 Clamshell CD Faceplate Replacement
O que você precisa
  1. iBook G3 Clamshell CD Faceplate Replacement, Battery: passo 1, imagem 1 %32
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell CD Faceplate Replacement, CD Faceplate: passo 2, imagem 1 %32
    • Use a straightened paperclip to manually eject the CD-ROM tray.
  3. iBook G3 Clamshell CD Faceplate Replacement: passo 3, imagem 1 %32
    • Remove the single black Phillips screw from the center of the CD-ROM bezel.
  4. iBook G3 Clamshell CD Faceplate Replacement: passo 4, imagem 1 %32
    • Grasp the CD-ROM bezel and rotate it upward to remove it from the drive.
    If you rotate the bezel upward as described- you SNAP OFF THE TAB THAT YOU REMOVED THE SCREW FROM, which is what ATTACHES the bezel to the drive!!!. THANKS!
    quayd - Responder
Conclusão
6 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
2 comentários
There are two small black phillips screws which ALSO need to be removed ...... on some models. Although appearing identical, these covers are "similar" but NOT interchangeable between models of CD-Rom.
John Foster - Responder
Help I've broke my drive cover and it won't go back on how do I fix that
Mr. Yee Macinuwm - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 10,052
