Introdução
Replace or change the CD drive faceplate.
O que você precisa
Use a coin to turn both battery locking screws 90 degrees to the left.
Remove the battery cover.
Remove the battery from the computer by pulling up on the plastic tab.
6 outras pessoas executaram este guia.
Documentos anexados
2 comentários
There are two small black phillips screws which ALSO need to be removed ...... on some models. Although appearing identical, these covers are "similar" but NOT interchangeable between models of CD-Rom.
Help I've broke my drive cover and it won't go back on how do I fix that
